Author Topic: Water temp light flashing  (Read 4106 times)
Offline moby dick
« on: 07 October 2010, 12:07 »
The watere temp light is flashing intermittently on my 90 Mk2. There doesn't seem to be a problem with the water as the levels are fine and the temp indicator doesn't get much over half way. The light sometimes comes on from cold and other times when the temp gets to normal on the guage. Any suggestions for the cause?
\\\"I spent a lot of money on booze, birds and fast cars. The rest I just squandered\\\" George Best
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Water temp light flashing
« Reply #1 on: 07 October 2010, 12:36 »
I had this with mine & It was the temp sender unit...
Got a Proper VAG one and sorted It...
I would read RJ's thread on checking the coolling system in the Info & Mate section (Top of Page) before buying one, just in case its something else...
HTH
For More Info Click To See;
Offline X4MGS
  • VAG Parts SNOB!!!
Offline moby dick
« Reply #3 on: 07 October 2010, 17:36 »
Thanks, I'll have a look at that
Offline beechymonza
  • mad beech
« Reply #4 on: 09 October 2010, 15:03 »
Mine did this for 9 years, In the end someone told me 2 remove a realy, Cant remember which 1 now, But it on eya somewhere,
All sorted now,
No guts No glory,
Offline moby dick
« Reply #5 on: 09 October 2010, 16:00 »
I have fingers crossed writing this - that makes typing difficult. I unplugged the blue temp sender and then replaced it. The light does not now flash but does light up on ignition so I am hoping that this has solved the problem.  :shocked:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #6 on: 09 October 2010, 20:00 »
You mean the one in the cluster of lights? If so it should come on when you turn the ignition on.. and then go off!!
What does the temp gauge read when the car is warmed up??
Did you top up the expansion tank with some G12 Antifreeze??
Offline sparks03
  • Look at the veins in that
« Reply #7 on: 09 October 2010, 20:03 »
Be careful to monitor the fluid levels over the next few weeks. Could be early signs water pump is on the way out.
<br />   Heaven is 13 feet long
Offline moby dick
« Reply #8 on: 10 October 2010, 08:20 »
Yes the cluster water temp light flashes during ignition and then goes off (it was that light that was flashing). Temp guage is OK just over half way when warmed up and coolant levels are steady.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 10 October 2010, 14:16 »
Sounds like it working properly to me.... Just keep an eye on the levels and top up accordingly!!
