Author Topic: 3dr to 4dr loom??????  (Read 2896 times)
Offline alva 16v
« on: 06 October 2010, 22:35 »
can i put a 3dr 16v loom into a 4dr or will i need a 4 door 1 if any 1 no's, cud they let me no id much apreaciate it cheers,,,,,,,,,,,,?
Offline SoundillusioN
Re: 3dr to 4dr loom??????
« Reply #1 on: 06 October 2010, 22:40 »
you havent said what car it is!?.... and what loom,  or all of them, anyway its 99% yes either way (apart from interior door light wiring maybe).....
Offline alva 16v
« Reply #2 on: 06 October 2010, 22:49 »
its a mk2 f reg 16v 2dr loom into a 4dr 90 spec or will i need a f reg 4dr 1 cheers..............
Offline alva 16v
« Reply #3 on: 06 October 2010, 22:53 »
its a 90spec golf.......
« Reply #4 on: 06 October 2010, 23:24 »
Should be the same but early and late looms are different, seems a backward step to be honest.
« Last Edit: 07 October 2010, 15:45 by Wayne »
Offline Simeon
« Reply #5 on: 07 October 2010, 13:32 »
Why would you put CE1 wiring into a CE2 car?
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #6 on: 07 October 2010, 15:44 »
Won't the clocks 2 pin & 1 pin, dash Hazard & stalk wiring be different??
For More Info Click To See;
Offline alva 16v
« Reply #7 on: 09 October 2010, 22:42 »
i hav a 3 dr f reg mk2 golf 1.8 16v an a 4 dr 90 spec mk 2 8v can i get a 3 dr 90 spec  loom 2 wrk with a pre 90 engine i hav the loom 4 this engine will it wrk if i change the hazard  switch or shal i just 4n an auto electrition 2 wire it in cheers....
« Reply #8 on: 09 October 2010, 23:49 »
I am struggling to read / make sense of this post.  :rolleyes:
Don't think a 16v loom will be any good for a 8v.
Offline Simeon
« Reply #9 on: 10 October 2010, 01:48 »
So you are putting the 16v engine from the F-reg into your 90spec 8v gti?
