Author Topic: oil temp/water  (Read 2627 times)
Offline Rob
oil temp/water
« on: 17 August 2003, 11:57 »
after recent head skimming, water pump, matrix, thermostat etc.
Can anyone please help me out on various readings.
When car warm, {afer driving for ten minutes }
Oil is between 96 and 100
Water is around half way
is this about average as dont want to have head trouble again.
mk2 8v gti 1990
Offline pipworks
Re:oil temp/water
« Reply #1 on: 18 August 2003, 08:50 »
Oil sounds the same as mine, water seems a bit hot? Mine runs at 1/4 and goes to 1/2 in traffic then the fan cuts in, it's never gone above 1/2.
What's it like in traffic? If it doesn't go over half I'd say you've nothing to worry about.
golfvr6
Re:oil temp/water
« Reply #2 on: 23 August 2003, 18:03 »
Rob,
Your readings sound spot on , nothing to worry about. It is normal for the water temp to go up to 2/3's in heavy traffic until the fan kicks in.
Offline tizer2000uk
Re:oil temp/water
« Reply #3 on: 25 August 2003, 09:08 »
Mr Pipworks, you might want to check your thermostat as it seems you might be overcooling the engine.  Dont suppose its too much of a bad thing....
golfvr6
Re:oil temp/water
« Reply #4 on: 25 August 2003, 14:51 »
I think you might be right there. Problem with faulty thermostats sticking open means the car takes ages to warm up ,usually lots of fuel wasted.
« Last Edit: 25 August 2003, 14:51 by golfvr6 »
