Author Topic: refurbing starter motor  (Read 5831 times)
Offline Khare
  • The bear that khares
« on: 05 October 2010, 22:02 »
Hey guys, just wondering if there's any way of refurbing the starter motor as mine is about to die. Is there anything I can change if I open it up and take it apart?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: refurbing starter motor
« Reply #1 on: 05 October 2010, 22:07 »
I have refurbed many in my time,  then i tried my golf one and bits flew out allover the floor and it went in the bin...  Good luck  :smug:
Seriously though,  to be honest unless you know how to do motor re-windings its not worth it,  the coils tend to deteriorate with heat,  new brushes etc.. probably wont be the issue.  Is it getting weak and struggling?  If so, and if its worse when the engine bay temps are high,  its probably going to be easier to slap a new one on  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Bellend
« Reply #2 on: 05 October 2010, 22:46 »
Got a new one for £33 for an 8V engine.
I know its still money for students but not a bad price.
Where all my moneys went.
Offline Ben Lessani
« Reply #3 on: 05 October 2010, 22:52 »
No harm in trying a refurb. It does ping apart when you dismantle it - so just take it easy. I'd be inclined to check the bushes (11mm minimum IIRC) and the bell housing bush, then clean up the armature, perhaps re-solder a 4awg replacement braided wire (if it is in bad condition) to the solenoid.
Could spend a couple of hours cleaning it up and about £10 on parts. If it doesn't work, at least you learnt a little - if it does work, you'll have an awesome sense of satisfaction!
Offline Deano2711
  • 1992 VR6
« Reply #4 on: 05 October 2010, 22:53 »
Are the 8v and 16v starters the same ??  If they are then I have the one off the 8v I'm breaking you can have cheap Khare. Let me know. By the way was the coil ok for yours Mate??     Cheers
Offline Bellend
« Reply #5 on: 05 October 2010, 23:13 »
I'm not too sure.
I think they are, yeah but don't hold me to that.
Offline Khare
« Reply #6 on: 06 October 2010, 02:02 »
Yeah its struggling to crank over, I'm pretty convinced its the starter motor as opposed to the battery, and especially since It's gone flat, you turn the key and you get half a crank, then stops for about 2 seconds then slowly comes back to life again. Before the flat battery it would be 6 out of 10 times, since getting it going its been every time. New battery on thursday though so that will confirm if its the starter or not. Pretty sure 8v and 16v starters are the same but ill find out when I get home and check etka and let you know Dean. Coil worked perfectly dude, couldn't have asked for a better deal or got it sooner!  :cool:
« Reply #7 on: 06 October 2010, 08:00 »
Sounds more like a voltage drop to be honest or poor earth.
Offline Khare
« Reply #8 on: 06 October 2010, 09:51 »
Yeah I did think that, so I cleaned all the earths a few months ago but it didn't help. However why would suddenly the earths not do their job just because of the flat battery? I think the flat battery has caused it to fail even more.
« Reply #9 on: 06 October 2010, 09:54 »
Not sure but it would be worth rechecking the earths plus all the wiring to the starter 1st.
