Author Topic: How much to have a radio fitted???  (Read 2892 times)
Offline walchy01
« on: 05 October 2010, 17:03 »
Hi there, quick question...
How much to have a radio fitted these days standard cd/radio ???Thanks
Offline dubber36
Re: How much to have a radio fitted???
« Reply #1 on: 05 October 2010, 17:34 »
It all depends how much wiring is involved.
If it's a case of pluging in an adaptor harness, it'll take about 5 minutes, but if you need to put in new power and speaker wires it would take a couple of hours to do a tidy job.
So based on that I'd say anything between £5-40 + parts and consumables.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 05 October 2010, 18:04 »
Go and get a quote from Halfrauds.
Offline lingl9z
« Reply #3 on: 05 October 2010, 18:39 »
How bads the wiring that's the main thing as said above, It took me about an hour and a half to install a stereo (full rewire to ignition, 2 door speakers, cables to two amps in the boot to power 6x9's and a sub! the guy my mate used down here charged around £40 an hour.
Offline Ben Lessani
« Reply #4 on: 05 October 2010, 20:38 »
It will cost you ALL of your man points.
Stereo's are beginners electrics and an easy DIY task (until you find half the loom is missing/scotch locked or taped up) :laugh:
Offline messenjah
« Reply #5 on: 05 October 2010, 20:58 »
if it wasnt butchered last time its a piece of piss and paying someone to do it would loose you some serious man points ... if its been butchered then it can be a pita
Offline walchy01
« Reply #6 on: 05 October 2010, 21:28 »
Sorry to let the side down but I am not any good at much diy stuff :cry:
Has anyone got a simple diagram???
Much appreciated
Offline Ben Lessani
« Reply #7 on: 05 October 2010, 22:27 »
simple enough? :laugh:
Offline danny_p
« Reply #8 on: 05 October 2010, 22:53 »
as previously said. you will loose all man points and you will have to go and buy a skirt and handbag
all the VW's have gone bar 1.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 06 October 2010, 01:27 »
Much appreciated
Bring it over and I'll fit it for you!!
Hours job Max!!
For More Info Click To See;
