Buy some oil flush from halfords, add to the oil, ONLY run the car at idle, when the fan kicks in, drop the oil, replace with new oil and filter.
May vary with product, some you have to run at fast idle for 15 minutes, some just at idle for 5 minutes, some you add 100 miles before you are due the oil change.
whats the stuff called that ya can get to flush all the old oil completely out of the engine? and is there any major advantage to doing it? MInes due an oil and filter change soon, if its worth the hassle, i'll flush aswell
Quote from: KhareMay vary with product, some you have to run at fast idle for 15 minutes, some just at idle for 5 minutes, some you add 100 miles before you are due the oil change.I wouldn't use anything that says to drive the car with the flusher in.
Quote from: AudiA8Quattro on 04 October 2010, 17:12Quote from: KhareMay vary with product, some you have to run at fast idle for 15 minutes, some just at idle for 5 minutes, some you add 100 miles before you are due the oil change.I wouldn't use anything that says to drive the car with the flusher in.Actually, the method of draining 500ml of oil and refilling it with 500ml of ATF involves driving it for a week or so before doing the oil change.
