Author Topic: Massive Problem With my MK3 HELPPP PLEASE!!  (Read 1632 times)
Offline imran92
« on: 04 October 2010, 12:59 »
okay, here it goes. i have got a mk3 1.4 engine code ABD, a mechanic has just put in another engine into the car (same engine code) because my original engine was completly f**ked! (head gasket and tappets), we have changed the spark plugs, rotor arm and distributor cap but the car cuts off as soon as i let go of the key, if i hold the key  right at the end of the ignition it stays on, however as soon as i let go the engine just dies!!
i've tried to explain as best as i can, and i really need help with this as i need it to get to uni this week!!
Thanks
imi
a old school car WILL break down, thats the fun part about them :-P
Offline Khare
  • The bear that khares
Re: Massive Problem With my MK3 HELPPP PLEASE!!
« Reply #1 on: 04 October 2010, 13:14 »
Sounds like the ignition switch could be faulty.
Offline imran92
« Reply #2 on: 04 October 2010, 13:17 »
the mechanic said that it's the carb, but i'm a bit skeptic about that, i think thats the right word LOL
if the engine's cutting out as soon as i let go of the key, that would indicate a ignition problem :S
god i'm confused lol
Offline DubSociety
« Reply #3 on: 04 October 2010, 13:19 »
Explain the whole situation to a different garage, and see what they say ...
It sounds like an ignition problem ...
billabong
« Reply #4 on: 04 October 2010, 13:28 »
When you turn the key to just before it cranks, are the lights on the dash?
W
« Reply #5 on: 04 October 2010, 13:30 »
+1 if your holding the key then it sounds knackered
Offline imran92
« Reply #6 on: 04 October 2010, 13:31 »
yep, all the lights come on and it starts but as soon as i let go of the key the engine just cuts off,
if i hold the key right at the end of ingtion i can rev the engine
« Reply #7 on: 04 October 2010, 13:36 »
Sounds like to me your ign. switch has died, I would be carefull holding on the key as that will be keeping the starter in which will in the end burn it out.
Offline VR6_Wherry
« Reply #8 on: 04 October 2010, 14:05 »
+1
Then you will have an ignition switch and starter to pay for!
My money is also in the ignition switch as i've had the same issue.
Offline imran92
« Reply #9 on: 04 October 2010, 18:04 »
okay, brought a new ignition switch, is it possible to change it without pulling of the steering wheel column?
