Author Topic: a bit of advice pleeeaaassseee  (Read 1966 times)
Offline matping
  • MK1 20vT MK5 GTI T
« on: 02 October 2010, 16:30 »
guys i have a mk4 20v turbo and want a oldskool golf so im going to buy a mk1 golf cabriolet  but i want   a 20v turbo engine putting in it  is this hard to do ? i have all winter to do it and a barn to work in !  ready for the summer shows!
Offline raferackstraw
Re: a bit of advice pleeeaaassseee
« Reply #1 on: 02 October 2010, 17:11 »
from the threads ive read putting in the engine itself isnt particularly hard, a bit of fabrication for mounts is required. the hard part comes with the wiring. if you use stand alone management its a bit easier and qpeng do a complete plug n play kit. if you use original ecu then you have the immobiliser issues which can be a nightmare. with stand alone you are going to have costs in mapping the engine/ rolling road time. other problems arise if your going to use a cable change gearbox, but there are solutions out there you just have to search.
have a look on the mk1oc website there's afew peeps done this conversion  :wink:
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline matping
« Reply #2 on: 02 October 2010, 17:18 »
cheers buddy im going to have a crack at it whatever  and yes i was thinking about the ecu the outherday . i asked about some mates and got a contact that does the standalone " plug n play system "  ill  check out the threads
« Reply #3 on: 02 October 2010, 21:03 »
It is better if you can to run the factory managment setup.
Offline gibby
« Reply #4 on: 03 October 2010, 09:56 »
I thought we had a link in the maintenance section to vwvortex site, but I can't find it. Go to that forum and have a search http://forums.vwvortex.com/
......now officially dubless.
