Author Topic: Low Temp Reading  (Read 1966 times)
Offline Mamma
Low Temp Reading
« on: 01 October 2010, 13:42 »
Hello,
I have a Golf 1997 1.6GL.
For the past 6 months the temp gauge has hung about the lower quartile never quiet making it to the middle- gets to the middle in traffic however drops down to the cold zone when driving.
The blower is always blowing warm/hot heat so i am assuming that the car is heating up ok.
I was advised to change the temp sensor- I have done this and there is no change- the temp gauge is still staying at the lower quartile
Any one of any ideas of what it could be?
The car runs perefect- no spluttering etc
Re: Low Temp Reading
« Reply #1 on: 01 October 2010, 13:45 »
Air lock or blocked radiator.
Offline Mamma
« Reply #2 on: 01 October 2010, 13:51 »
ok, thanks- how do I eleviate an air lock?
Offline Khare
  • The bear that khares
« Reply #3 on: 01 October 2010, 14:01 »
Exact symptoms of a faulty thermostat  :smiley:
Wayne, blocked radiator or airlock would cause overheating, not underheating.
Offline Mamma
« Reply #4 on: 01 October 2010, 14:08 »
Ok- Thanks- will get it checked out
Offline Khare
« Reply #5 on: 01 October 2010, 14:09 »
to test it start the car from stone cold and let it warm up on idle, touch the bottom radiator hose, if it warms up at the same time as the top radiator hose then it's the thermostat. If the top hose is very hot when the bottom hose starts to warm up then the thermostat is fine.
Offline Mamma
« Reply #6 on: 01 October 2010, 14:13 »
Hello Khare - thanks for ur advice- will test it tomorrow.
Thanks
« Reply #7 on: 01 October 2010, 14:15 »
Not always, my BMW 520 was underheating due to a blocked radiator.
However it could be a thermostat problem.
« Last Edit: 01 October 2010, 14:17 by Wayne »
Offline Khare
« Reply #8 on: 01 October 2010, 14:16 »
No worries and good luck, and don't be put off it is the thermostat, it's an easy job.
Somehow I fail to believe it was a radiator blockage  :wink:
Offline snifferdog
« Reply #9 on: 01 October 2010, 14:48 »
Sounds like the thermostat to me, same problem the mrs had on her polo!
