Author Topic: How do I tell the difference between a K Jet and a Digi?  (Read 6045 times)
Offline Horney
Re: How do I tell the difference between a K Jet and a Digi?
« Reply #10 on: 02 February 2005, 10:03 »
Well I bought it (see my sig) and it's a digifant. Goes like a bloody rocket! All I have to do is resist the temptation to start modding as it's supposed to be my daily driver. Not doing too well so far as a light Eyebrow has just arrived at work, off to the local autofactor at lunch to get some paint. Anyone know what colour that white is?
Offline Gambit
« Reply #11 on: 02 February 2005, 12:46 »
alpine white - code L90E
Offline Horney
« Reply #12 on: 02 February 2005, 12:59 »
Gambit you are a gentleman and a scholar, thanks very much.
Offline Volkswagavin
« Reply #13 on: 02 February 2005, 13:43 »
The differences between digifant and K-jet....
The 8v golf changed from K-jet to digifant in 88, on the E plate (I think).  K-jet is mechanical fuel injection, whereas Digifant2 is fully-electronic injection.  Digifant suffers from a flat-spot just above idle which we know as Digilag, but the ECU can be reprogrammed to correct this.  K-jet doesn't suffer from the same problem but you can't alter the ignition timing with k-jet, sometimes causing problems with fuel below 98ron (ie normal unleaded).
There is a marginal performance difference between the two systems, the K-jet being quicker to 60mph.
The digifant has a reprogrammable ECU so you can remove and replace chips to improve performance and remove digilag.
To look at, as already said, there are a fair few pipes coming out of the top of the airbox on the k-jet.  There is little point putting an induction kit on the k-jet, it often upsets the system.
The mk2 golf changed from having 2-piece door windows to one piece during 88, so some cars have them, some don't.
I'd go for the digi 8v, although the k-jet 16v is in a different league entirely.
I reserve the right to be slightly wrong!
Gav
Mk2 Golf GTI 8v - J reg
Offline Horney
« Reply #14 on: 02 February 2005, 13:56 »
Ok so now you have me confused and I'm not sure what I actually have! it's E reg and was first registered in 87! So it could be a K-Jet. It has two little hoses coming out of the side of the airbox if this helps anyone work out what it is!
Cheers,
Offline Horney
« Reply #15 on: 02 February 2005, 14:13 »
RIght I've just bought a haynes manual and the pic on page 1.7 shows an "Injected engine" This has LOADS of pipes coming out of the airbox unlike mine. So I'm guissing I have a digifant.
Offline Gambit
« Reply #16 on: 02 February 2005, 14:58 »
yes you have a digi. there is a bout 8 pipes coming out of top of the airbox on a kjet
<Question for all!> just outta curiosity. do all Digi's run the later electrics. i.e. is the hazard switch on the steering column shroud???
Offline Horney
« Reply #17 on: 02 February 2005, 15:11 »
No, cause mine has the hazards on the dash switch!
Offline Alexg40
« Reply #18 on: 02 February 2005, 22:26 »
Just to add to the confusion. Mine is an 89 with what you are describing as K-Jet. This doesn't tie in with the above.  :shocked:
free
« Reply #19 on: 03 February 2005, 04:10 »
a digi
A K-JET
Can you tell wich 1 belongs to may mate, n wich is out of a show car :evil:
these are 8v's,,,,,,,16v's only came in k-jet
« Last Edit: 03 February 2005, 04:21 by free »
