Author Topic: Testig the coil?  (Read 653 times)
Offline B-chi
Testig the coil?
« on: 01 October 2010, 06:23 »
Searched through the site yesterday and came to the conclusion the coil was bust.
Had a look and it was cracked so thought it was a no brainer. A friend said dry it out then resin it to stop it happening again. I got back from work about 6:00pm, started her up and left her running. Then about 5mins later she stalled and hasn't started since.
Last night at about 11:00pm I noticed the earth lead from the coil to engine had snapped. I repaired it, checked it was good with a DMM. Still not working.
How do you test the coil to see if it's working?
I'm in the process of moving house and I've got a car audio final on Saturday to get to in Essex. Argh help
Offline shanco73
Re: Testig the coil?
« Reply #1 on: 01 October 2010, 11:20 »
Check to see if you are getting a spark on one of the plugs, if your not then you can pretty much be sure in your case that your dodgey coil is duff.
Offline Deano2711
  • 1992 VR6
« Reply #2 on: 01 October 2010, 11:27 »
If the old coil has cracked then it would just be easier to replace it really Mate. A new one is not that expensive and a second hand one even cheaper.
