Author Topic: mk1 clipper cab running probs  (Read 2009 times)
Offline robiwill
« on: 30 September 2010, 11:25 »
Hi guys turning to you for help as it is doing my and Steve's head in
got a clipper 1.8 carb model
engine been rebuilt all timming correct etc
new webber carb fitted
replacement fuel filler neck
when cold starts fine a bit hessatant but runs
when it has been driven for about 20 minutes it loses power and you have no revs and then stalls. will start again but will not drive in any gear above 2 untill it cools down
It was the same before the engine was rebuilt just it rattled hence the rebuild.
any ideas as the car is really doing my head in
Offline Agreeable Slick
  • Unit
Re: mk1 clipper cab running probs
« Reply #1 on: 30 September 2010, 11:37 »
Assumming the carb has been set up, and the fuel lines are all clear?
Offline robiwill
« Reply #2 on: 30 September 2010, 13:11 »
yes all clear new fuel line filter fitted as old one was manky and still clear now car has done 20 miles since rebuild  carb was brand new from webber
Offline clipperjay
« Reply #3 on: 02 October 2010, 16:59 »
Had a simular issue the only thing that worked was to change out the fuel tank apperently there was loads of rubbish sitting in the swirl pot where the fuel was getting sucked from and restricted the fuel flow into the fuel pump & pipes.
The symptoms are like fuel starvation or kangaroo first notice it on mine but the sign of a rusty fuel neck was bang on the money!
Offline smokey gti
« Reply #4 on: 07 October 2010, 21:55 »
Might help i had an old mk 1 xr2 same problem tried everthing then a mate of mine an old school mechanic told me to get a flexy petrol cap drill a small hole in it and run it. tank was pressurising and starving carb of fuel dont know if that will help but it cured mine. it was just coincidence it stalled at temp cos the pressure built up as it was running.
mk 1 gti cab mk 4 18T fun in the sun and fun in the rain
Offline Royalblue
« Reply #5 on: 10 October 2010, 20:23 »
My Mk2 had this problem once. I would go funny and eventually stall when warm. Cooled down again it would run for a while. I had to stop every 20 minutes to let it cool down. It was very worrying.
The garage cleaned the carburettor jets and the problem was solved.
Another thought: Have you checked all the breather pipes?
« Last Edit: 10 October 2010, 20:25 by Royalblue »
Golf Mk2 - Aus Liebe zum Automobil
