Author Topic: steering getting heavy randomly  (Read 2221 times)
Offline gazman1011
  • if your not first, your last!
« on: 29 September 2010, 10:18 »
every now and then my power steering gets really heavy. wat could it be? can it be fixed or get a new one? where is the power steering pump situated?
thanks
Offline snifferdog
Re: steering getting heavy randomly
« Reply #1 on: 29 September 2010, 10:25 »
Could be the power steering belt?! This is known to happen more in wet weather.
Offline gazman1011
« Reply #2 on: 29 September 2010, 10:34 »
how do i check and where is it?
Offline Deano2711
  • 1992 VR6
« Reply #3 on: 29 September 2010, 10:40 »
It's on the left hand side of the engine Mate as you look. There is an alternator belt (fan belt) and the power steering belt both together. Right next to the inner wing. I would have thought that if the belt was at fault the problem would not be intermittent.  Also check the fluid level while you are there.
Offline luckycharms
« Reply #4 on: 29 September 2010, 10:45 »
happened mine too, particularly at tight roundabouts. I also got belt screeching near full lock while parking
Might be worth giving the belt tensioner a squeeze, solved mine
Offline Len
« Reply #5 on: 29 September 2010, 10:50 »
Yep will be the belt!
You can re-tension it but that wont last long. Best to replace it. They only cost a fiver from ECP. (£4.82) Make sure you get the correct one as it depends if you have air-con or not!
Fairly simple job but has to be done from underneath as you have to drop the undertray anyway.
Also do check the fluid level.
I did this to mine recently and made a big difference to the steering!
On my 4th belt in 7 years, so that shows they need regular attention.
www.sas.org.uk
www.the-ace.org.uk
Offline jonnygti66
  • GOLF MK4 GTI V5
« Reply #6 on: 29 September 2010, 11:57 »
+1 on that one!!  :smiley:
quicker than a granny in a knitting race ;)
Offline gazman1011
« Reply #7 on: 29 September 2010, 18:07 »
thanks all, going in garage tomoz for a new belt fitting, hope it solves it, ill let you all know
Offline stainesy
« Reply #8 on: 29 September 2010, 22:02 »
is it in wet weather when this happens?
on my old mk3 golf when ever i went through a pudle or any water my power steering would not work as the water would go up into engine bay and make belt slip.
Offline gazman1011
« Reply #9 on: 30 September 2010, 09:34 »
yea its more when its inwet weather! p1ssed me off lol
