Golf mk2
urgent question on Allen key size
Topic: urgent question on Allen key size (Read 1947 times)
The Mighty Elvi
I'm better than you today.
28 September 2010, 13:36 »
I'm changing the rear discs and pads on my 91 valver. What size are the Allen keys neede to remove the caliper carrier. Off to shops to buy some now so prompt response appreciated.
Thanks.
Jonathan.
Agreeable Slick
Global Moderator
Serious forum addict
Unit
Re: urgent question on Allen key size
28 September 2010, 14:31 »
IIRC 7mm...
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
The Mighty Elvi
28 September 2010, 14:37 »
Thanks. CGTi says 8mm so ill buy a set to be on the safe side.
The Mighty Elvi
28 September 2010, 15:55 »
Yup. Deffo 8mm. Halfrauds even sell a special tool for the job. Long arm HEX. £5.99.
Now only if it would stop raining.
Steve_B
28 September 2010, 19:21 »
Can use the VW wheel wrench as an extension for the allen key as it's hollow. A bit pikey but it works
The Mighty Elvi
28 September 2010, 23:22 »
Tried that. May need to give Garth a call.
Mew
Reply #6 on:
28 September 2010, 23:33 »
I found that a 15mm socket hammered over the bolt worked well. Someone had previously attacked the bolts on mine and completely rounded them off
Ben Lessani
The poor mans MK2 Haynes author
Reply #7 on:
28 September 2010, 23:37 »
I was pretty sure its 7mm
I had to cheat and grind flats on to mine!
twistedblack69
Proud mk2 user and abuser
Reply #8 on:
29 September 2010, 00:08 »
As long as it gets 'em off lol. I was lucky, the brakes weren't too much of a ballache, whereas everything else on the car so far has been seized
Golf mk2
