Author Topic: Brake sizes required  (Read 1358 times)
Offline Doddy01
  • Golf MK4 GtTdi 130bhp and luvin it
« on: 28 September 2010, 11:24 »
Hi All Need to replace my Discs and pads all round on my GtTdi 130Bhp 02 Plate now before i take the wheels off thought i would see if anyone knew the actuall size.
front(vented) discs 5stud fitting iv seen 3 different types 288mm/256mm/280mm i think mine are 288 as when i put my reg number on certain sites its saying 288mm for performance discs but nothing for the standard..also gives me an option for pads with the sensor on
Also are the rear discs 232mm on solid discs or are they vented too
Any advice appreciated if not looks like i will be taking wheels off when i get in from work
Offline tech1889
  • Mk2 GTI FTW !!
Re: Brake sizes required
« Reply #1 on: 28 September 2010, 11:47 »
280mm fronts vented.. 232mm rear solid disks.. you need the pads with the sensor in as it tells you when they are worn down so you dont have to keep checking..
Offline Rhyso
« Reply #2 on: 29 September 2010, 10:35 »
288mm front  :wink:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 29 September 2010, 11:55 »
thought only gti had 288 fronts ?? tdi had 280 ??
Offline Rhyso
« Reply #4 on: 29 September 2010, 11:57 »
Thought wrong then didn't you  :tongue:
130 and 150 TDI's had the 288mm brakes.  Rest of the range had the 280's  :nerd:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #5 on: 29 September 2010, 11:59 »
Well in that case the reply to the first answer will be 288mm front vented disks  :rolleyes:
Offline Doddy01
« Reply #6 on: 29 September 2010, 21:56 »
Yeah front Discs are 288mm with pads having the sensor on them as Rhyso pointed out this is only on the 130/150bhp models ..
Rear are 232mm solid
Decided to go for miltex grooved discs on the front and just standard miltex on the rear with matching pads cost more but surpose cost is alot less than going into the back of another car after seeing some of the cheap stuff listed on ebay
