Author Topic: car keeps cutting out.  (Read 2503 times)
Offline km
« on: 27 September 2010, 19:20 »
anyone fancy solving this?
got a 1.8t agu. doesn't cut out all the time, usally once every fortnight maybe? but it's done in 3 times in the last 5 minutes. getting very frustrating. and when the car's idling, the revs like to drop and shoot back up. and sometimes, the throttle pedal seems to do nothing, it's almost as if it's been disconnected. for example, i'm driving along in 3rd, change to 4th, but the car doesn't build up any speed. sometimes the car just stops for a split second (very similar to tapping the brake pedal)
any help will be appreciated thanks.
Offline richw911
Re: car keeps cutting out.
« Reply #1 on: 27 September 2010, 20:48 »
Offline km
« Reply #2 on: 27 September 2010, 21:38 »
Had car at r tech about 2 months ago, and they cleaned it I think. Still think it's worth a clean? Think it could be anything else causing this? :/ thanks
Offline DarkGti
« Reply #3 on: 28 September 2010, 10:31 »
could be a number of things tbh mate best bet is to get it vagcom'd
Offline vwprime
« Reply #4 on: 28 September 2010, 11:18 »
At a gess the ignition amp or maybe the MAF. Are you running the stander air box or a indution kit?
TRANSFORM, & ROLL OUT!
Offline km
« Reply #5 on: 28 September 2010, 11:25 »
think it's time i get vagcom  :undecided:
used a scanner, but no fault codes came up.
had a new maf 2 months ago. and running standard air box. cheers!
Offline vwprime
« Reply #6 on: 28 September 2010, 11:31 »
I did have a spit nose pipe runing from my N75 once that had simler things happen to what you have said KM, but not as bad. But i think a falt code would have crop up by now it that was the case but maybe work having a look?
Offline km
« Reply #7 on: 28 September 2010, 12:05 »
would a weak n75 be my problem by any chance? i've been told to get it changed but haven't got round to doing it  :laugh:
Offline vwprime
« Reply #8 on: 28 September 2010, 13:41 »
Wouldnt like to say mate for shore. I could see it corsing some of thoes problems but not nessesarly all of them.
Offline km
« Reply #9 on: 28 September 2010, 15:28 »
hmm, happened again today. had my foot fully pressed on the accelerator pedal and car was just rolling, no acceleration. I have to let go then press again in order to get it to work. put the clutch down.. and the revs just drop. i'll order a vagcom cable off ebay now  :undecided:
