Author Topic: Golf GTi Turbo Wont Start  (Read 4270 times)
Offline DYL4N
« on: 27 September 2010, 11:23 »
My car woudnt start yesturday. It was turning, but it wouldnt fire up.
I changed the spark plugs, and gave it a new oil and filter.
I tried starting again and it wouldnt. I kept turning over, and it eventually started.
I turned it off, then tried again, and the light came up "stop - oil pressure"
The warning has not come up since that.
I tried starting again and it fired straight away, but sounded like it was missfiring, drove it about 1 mile, and it was sorted.
But every time i start it, you need to keep it turning over, with your foot on the accelerator, and it will eventually start.
What could this be??  :shocked:
Golf Mk4 1.8T
Ko3s Turbo
Front Mounted Intercooler
Lighted and balanced flywheel
Stage 1 Re-Map
Lowered 40mm
18'' Rs4 Wheels
Offline tech1889
  • Mk2 GTI FTW !!
Re: Golf GTi Turbo Wont Start
« Reply #1 on: 27 September 2010, 11:27 »
Get vagcom on it and scan for codes could be MAF sensor..
Offline DYL4N
« Reply #2 on: 27 September 2010, 11:29 »
Its weird, because there's not EML on the dash  :undecided:
I disconnected the battery for a while, hoping this would have reset the codes.
Golf Mk4 1.8T
Ko3s Turbo
Stage 1 Re-Map
Lowered 40mm
18'' Rs4 Wheels
Offline adam1.8t
« Reply #3 on: 27 September 2010, 18:02 »
could be the crank shaft sensor i had similar problem with mine and thats what causeed me the fault cost me £16 iirc from gsf its located behind the oil filter
Offline speed_freak
« Reply #4 on: 27 September 2010, 18:05 »
I have the same issue with my girlfriends gti on a morning it's right pain in the arse to start I have to sit there with foot to floor to get it to start it's really lumpy smells really chokey keep it revving for around a minute then it's fine will start up rest of the day I have been told it could be the temp sensor but yet to have that changed I unplugged the mat made no diference to it so I too could do with some answers to it I have scanned with vagcom apart from the usual 17705 code there was 1 for bank 1 sensor I think
Offline DYL4N
« Reply #5 on: 27 September 2010, 20:11 »
Yep, same problems as mine.
Ill get a new crank sensor and temp sensor tommorow. See how it is then
Golf Mk4 1.8T
Ko3s Turbo
Stage 1 Re-Map
Lowered 40mm
18'' Rs4 Wheels
Offline speed_freak
« Reply #6 on: 27 September 2010, 21:03 »
Update the thread mate when you sort it
