Author Topic: last check before buying coilovers  (Read 1589 times)
Offline andyj775
« on: 26 September 2010, 18:51 »
right, coilovers are next on my list, and ive settled on the fk coilovers from venom motorsport. im also getting the venom anti roll bar so i can go low and im getting spacers all round too. my question really is how thick do the spacers have to be to safely clear the coilover adjustment rings on the fronts? i dont want to go too wide, just need to know a safe minimum if that makes any sense. thanks in advance
andy
Offline vwfiend
Re: last check before buying coilovers
« Reply #1 on: 26 September 2010, 18:59 »
I have fk ak coilovers from there without the anti roll bar and have et35 anni alloys which clear the adjusters by just over a rizla pack width which is fine as this gap never changes....... Unless you get a flat tyre then it shreds it up as I found out with a Michelin pilot 3!!!! For peace of mind go for a hubcentric 5mm or if your tight like me then leave it!  :grin:
Offline andyj775
« Reply #2 on: 27 September 2010, 09:49 »
thanks for the reply, so i take it youve taken the a.r.b. off completely then? apologies if ive got that wrong but id rather get the one with bigger hoops as im only lowered 40mm at the moment and its not far off the driveshaft already
Offline vwfiend
« Reply #3 on: 28 September 2010, 00:28 »
No I would never take off the anti roll bar!!!! I want a rear one first as it can make a FWD car handle worse by upgrading the front ARB without doing more-so to the rear and the opposite on a RWD. On the roads I have to endure, it's really not practical to stroke the sump against the road. When I do buy the ARB's I'll either get Neuspeed, H&R or whiteline. Possibly even eibach.... as I've heard that the cheaper (jom, fk et al) are rubbish. I'd try it first and see how you get on......
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #4 on: 28 September 2010, 11:52 »
You would never take the ARB off completely thats just silly lol.. As said above uprate the rear (well actually put one on) and then upgrade the front..
