Author Topic: Water pouring out the water tank!  (Read 1064 times)
Offline jocarl11
« on: 26 September 2010, 12:15 »
Hi guys, water is p1ssing out of the filler tank on my 16v but it seems to be coming up from the electrical connection plastic nut and not the cap! Is this a common problem or could it be the head gasket? The water doesn't boil and there is no oil in the water which must be a good sign?
Cheers.
Offline weazgti
Re: Water pouring out the water tank!
« Reply #1 on: 26 September 2010, 12:40 »
Your cap has failed,pull it off and check the seal.Most people just change them for a blue one.
The water is coming out there because there is an overflow hole in the side where you say it is coming out.
Offline jocarl11
« Reply #2 on: 26 September 2010, 15:52 »
Thanks, the cap is blue but I can hear hissing from it when the engines warm so must be that then! Cheers for the help  :smiley:
« Reply #3 on: 27 September 2010, 09:13 »
sounds liek its the level sensor that has failed, gsf sell these i think
