Author Topic: master brake servo and ABS question  (Read 9892 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
« on: 26 September 2010, 01:27 »
is there a way to check the Master brake servos working ok ?
also i think i have a problem with my ABS pump can you get air in it ? as i ve been having some brake problems and ive had them bleed twice now brakes fine just the peddle feels a bit spongy
THankS
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline richw911
Re: master brake servo and ABS question
« Reply #1 on: 26 September 2010, 10:11 »
Vag Com needed   :smiley:
Offline ggggolfgti
« Reply #2 on: 26 September 2010, 12:55 »
just found this out myself, if you have air in the abs pump you need vagcom to sort it
did you bleed the master cyclinder on both nipples??
luckily i didnt need the vagcom when i done mine
249 bypass, ths fr3 engine mounts, S/S decat, 2.5'' straight through exhaust, induction kit, forge split r, coilovers, 18'' alloys, much more in the pipeline
Offline houston
« Reply #3 on: 26 September 2010, 14:11 »
put key to ignition and pump brake pedal till it goes rock hard, then with pressure on pedal start the car, if pedal goes down slightly then your servo is working fine
Offline godsANGER
« Reply #4 on: 26 September 2010, 14:17 »
Easy to do? and do i just need the Vag cable and software
. . Probaly nieve of me but only did the callipers  :undecided: did rear passenger, rear drivers, passenger side then drivers. didn't even think about the Master cylinder it self, is it easy/same as doing the callipers ?
Offline godsANGER
« Reply #5 on: 26 September 2010, 14:18 »
i can pump the pedal hard . . ish i can still force it down a bit if i really force it and i do get kick back when i turn the ignition so not the servo then
Offline houston
« Reply #6 on: 26 September 2010, 14:40 »
no, not servo then, looks like your in the same boat as me right now, im gonna try bleeding some time but i have the usual habit of snapping the nipples :angry:
Offline godsANGER
« Reply #7 on: 26 September 2010, 14:50 »
Well i had fun yest replaced 3 bleed nipples as there were foobard and then had fun with a sheared bolt and a odd drop link http://uk-mkivs.net/forums/t/379564.aspx
Going to get hold off Vag com and wire then bleed all again and master servo then prim ABS pump and see how it is after.
How had is it to do the servo and the vag the ABS ?
Offline houston
« Reply #8 on: 26 September 2010, 15:49 »
bleedin servo is easy, just 2 8mm nipples, vag com i cant help with as ive never done it, but update this thread when you have cos i wanna try it on mine
Offline godsANGER
« Reply #9 on: 26 September 2010, 16:32 »
think ill try that tomorrow depending on the weather, ill post updates as they come matei
