Author Topic: What to replace? Entire Fuel Pump Unit or Fuel Gauge Sender Only  (Read 6515 times)
Offline invame
Hi all,
I've been having problems with my fuel gauge reading always full so today I decided to investigate. It turns out that the plastic arm of the spring/float has snapped in two. I've highlighted with a red line where it's snapped in the picture below. It's just held together by the wires now:
So my question is what do I need to replace? Can I replace just the top half minus the fuel pump itself or do I have to replace the entire thing. The sender unit is available as VAG part 1H0 919 670:
but all the connecting tubes worry me a little. Does anyone have any experience of doing this and if so could you advise please or if anyone can suggest any alternatives, I'm all ears. I thought about glueing it back together but if it comes apart again going over a bump I'm back to square one.
Any thoughts would be much appreciated,
InVame.
Re: What to replace? Entire Fuel Pump Unit or Fuel Gauge Sender Only
« Reply #1 on: 25 September 2010, 19:42 »
You should be able to replace just the sender unit.
Offline invame
« Reply #2 on: 25 September 2010, 19:49 »
There's no danger or difficulty in disconnecting the three pipes then? Can I do it from the boot by removing the fuel pump? It's just that I saw Len's post about having to remove the fuel pump by removing the tank. According to the Haynes manual I should be able to just turn the pump to the left and remove it.
« Reply #3 on: 25 September 2010, 19:52 »
Yes or drop Len a pm as his has done the job.
Offline invame
« Reply #4 on: 26 September 2010, 17:43 »
I've been having a think about it today and if I can get the fuel pump and sender out without too much difficulty I'm going to try fixing the plastic arm with some Q-Bond.
Offline Len
« Reply #5 on: 26 September 2010, 18:12 »
Dont believe what you read in Haynes!!!
It should twist but no way does it! Not without some special tool.
I found it almost impossible to change the sender without getting the pump out!
Now I know how though you dont have to take the petrol tank out!
Here's how - there's a 3 pronged holder fixed to the bottom of the tank. On each of the 3 prongs there is a rubber grommet, you have to prize the prong away from the pump and push a finger in between and push out the grommet.
Then the pump will lift out.
But by all means have a go at repairing the plastic break you showed above.
www.sas.org.uk
www.the-ace.org.uk
Offline invame
Thanks for the info Len. I managed to repair the arm about 2 weeks ago with Q-Bond. It's holding up well so far but if it breaks again I'll be using the above info to replace it.
