Author Topic: post cat lambda  (Read 1547 times)
Offline ggggolfgti
post cat lambda
« on: 25 September 2010, 18:00 »
i have the ebay decat the one that comes in 2 sections, but i only have the 1st part that bolts to the turbo so i got some stainless tube make up the rest
now there only the pre cat lambda, from what i have searched the post cat one can be mapped out, is this correct??
just want to make sure its ok before fitting
249 bypass, ths fr3 engine mounts, S/S decat, 2.5'' straight through exhaust, induction kit, forge split r, coilovers, 18'' alloys, much more in the pipeline
Offline ggggolfgti
Re: post cat lambda
« Reply #1 on: 25 September 2010, 21:35 »
bump
Offline ggggolfgti
Re: post cat lambda
« Reply #2 on: 26 September 2010, 12:30 »
bump on this, im going in for stage 2 map next week and my current decat has split on the flexi part when my dogbone mount went, so need to know if it will work or will need to buy new one
Offline ggggolfgti
Re: post cat lambda
« Reply #3 on: 26 September 2010, 18:12 »
bump again  :undecided:
