Golf mk4
Wazzzer
boot wont open
Topic: boot wont open (Read 1715 times)
matping
Here all the time
MK1 20vT MK5 GTI T
boot wont open
25 September 2010, 16:03 »
does any 1 know if there is a manual lever ? the fob stopped working or the motor has seized and i want to get in the boot the key dont fit in the lock aswell
JDM82
Here all the time
Re: boot wont open
25 September 2010, 16:05 »
Dont know about a manual lever but you could always pull the rear seats down to access your boot at the moment.
GOLF GTi - The legendary hot hatch
the_stink
Forum addict
A3 140 TDI
Re: boot wont open
25 September 2010, 16:47 »
use the key? even if the fob isnt working the key should
MKiv 1.8T >MkIV R32 >Mkii 16v > Audi A3
http://www.tonavaleting.com
www.flickr.com/photos/stink_photography
tech1889
Serious forum addict
Mk2 GTI FTW !!
Re: boot wont open
25 September 2010, 17:07 »
there is no manual lever just use the key if the key doesn't work your in for a lot of work trying to remove inner boot lining to get to mechanism..
Mk4 Golf GTI anniversary and mk6 golf tdi
houston
Re: boot wont open
26 September 2010, 14:21 »
go in through the boot, theres 2 screws, one in each handle, then just pull the trim off, you should then be able to push the lever to open the lock, my bet is the lock has siezed
Golf mk4
Wazzzer
boot wont open
