Author Topic: Radiator Fan not Switching on!  (Read 1578 times)
Offline 87_PROJECT
« on: 25 January 2005, 10:44 »
hi another question...
My radiator fan wont switch on. wheres the next place to check? Ive tested the fuse...and tried a different radiator fan...(I had a spare) Im presuming the next thing would be the sensor or switch itself...am I right in thinking these are both next to each other right in front of the engine...?
I have tried taking off/wiggling/cleaning the spade connectors but still no joy!...
So main question is which part shall I try next?
I found out the fan wont come on the hard way in London traffic the other day!!! (I overheated badly...) is there anything I should check after overheating...It seems fine?
Offline Mr Blue
Re: Radiator Fan not Switching on!
« Reply #1 on: 25 January 2005, 11:09 »
the fan switch is on the bottom right of the radiator.
mine doesnt work either :undecided:
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 25 January 2005, 11:12 »
mine only comes on if I've been sat in traffic for ages. if I'm moving it's fine.
Mk4 Golf 150PD
Offline Mr Blue
« Reply #3 on: 25 January 2005, 11:17 »
Could a faulty engine temp sensor relate to this?
Offline audiquattro
« Reply #4 on: 25 January 2005, 11:48 »
Must be a faulty fan switch.
As Blue said, bottom right side of radiator.
Offline 87_PROJECT
« Reply #5 on: 25 January 2005, 13:02 »
Thanks...again...
Ill give it a go... Doesnt really cause an immediate problem as Im only doing short journeys to work etc...
Wont be taking it in London traffic till fixed tho!!!
