Golf mk2
Help needed please
Topic: Help needed please (Read 1323 times)
White8v
Just got here
Help needed please
24 September 2010, 15:08 »
Hey all, Im new here and really could use some help soon. Basically i have recently bought a 1990 Golf GTi 8v in white, 3 door. And i think the engine is shot but thats getting replaced soon. My current problem is the relays and fuses under the steering column.
Could someone please post up a diagram or a picture of which relay goes where? As i have about 8 different relays in the glove box and 4 relays are missing. The numbers are still on the relays but i have no idea which one goes where.
As i need to get this thing running soon!
Thanks
boxer1968
GTI forum regular
Re: Help needed please
24 September 2010, 15:13 »
have a look in mk2 maintenance section theres a sticky on what your looking for
White8v
Just got here
24 September 2010, 15:20 »
If your on about the Fuse FAQ im well and truly confused.com lol.
X4MGS
VAG Parts SNOB!!!
24 September 2010, 16:19 »
Try this thread...
http://www.golfgtiforum.co.uk/index.php?topic=163818.0
Its got piccys of my relays in the order they are factory fitted with the CE2 Box....
I have changed the No19 relay (Front Wipers) with a No99 which allows you to have variable intermittent wipers...
Rest is bog standard...
HTH
For More Info Click To See;
My Thread On Here
Or
My Ebay Store!
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
27 September 2010, 09:09 »
you want to look at page 2, then check which fusebox you have. 90 should be the CE2 fusebox, but to double check look for your hazartd switch, on dash = pre-90 CE1, on column = post-90 CE2
Golf mk2
Help needed please
