Author Topic: Fitting front intercooler?  (Read 10363 times)
Offline nicksource
« on: 24 September 2010, 11:38 »
Has anyone fitted a front intercooler to a MK3?
Just wanting to know the best way of fitting one, any tips/guide?
Ideally wanting it like this: http://farm4.static.flickr.com/3559/3480608410_5068ea0cf3_b.jpg
Cheers,
Nick.
Offline Khare
  • The bear that khares
Re: Fitting front intercooler?
« Reply #1 on: 24 September 2010, 11:41 »
have you got a turbo?
Edit: You have a TDI, but I doubt it runs enough boost to need a big intercooler.
« Reply #2 on: 24 September 2010, 12:08 »
Not needed on your tdi really.
Offline Misky
  • MK3 16v GTI FTW!!!
« Reply #3 on: 24 September 2010, 13:41 »
Im sure i read that if you have a giant intercooler for a small boost set up you can potentially loose power.
MK3 16v GTI FTW!!!
Offline Jimp
« Reply #4 on: 24 September 2010, 13:52 »
This is a good forum to ask about diesel tuning:
http://forums.tdiclub.com/
Do note that there is a pressure loss as the air passes through the intercooler, the bigger the intercooler the bigger the loss, so if you are installing a front mounted intercooler you would want to have the car remapped/chipped, uprated pump, etc so you are pushing enough boost to make it worthwhile. A decent mid-term upgrade can be a mk4 GTI side mount intercooler as I think this is slightly larger than the standard TDI one.
Not low enough mk5
Not on the road enough mk3
Offline nicksource
« Reply #5 on: 24 September 2010, 19:28 »
Cheers Jimp though there isn't many MK3 owners there.
My question was on fitting it, not about if I needed one... I plan to upgrade the turbo in the future so will need an intercooler then.
« Reply #6 on: 24 September 2010, 20:49 »
Not really unless you running lots of boost, a bigger turbo will not gain much without more mods.
Offline ballin
  • Proper MK3
« Reply #7 on: 24 September 2010, 21:18 »
my mk3 intercooler is being fabricated this week i will post some pics of it when complete  :smiley:
AGU 1.8t... not diesel  :wink:
2003 MK4 Jetta VR6 24v 4M Supercharged
1996 MK3 Golf 1.8T 20v
Offline Khare
« Reply #8 on: 24 September 2010, 21:28 »
+1
Offline Jimp
« Reply #9 on: 24 September 2010, 23:40 »
Fitting depends more on how deep the intercooler is. A shallow one will fit easily enough. The deeper you go the more difficult it gets. You can get more space by pushing the radiator back with some custom mounts, or by cutting away are the slats in the lower part of the bumper. Go to the Dub Rides section and check out LazyLunatic's thread. He messed around with intercooler fitting a bit at one stage and could tell you more than I can.
Not low enough mk5
