Author Topic: Double check. Temperature.  (Read 1115 times)
Offline Big Tone
« on: 24 September 2010, 07:52 »
When I'm on the motorway my car's temp sits just under 90 deg occasionally. The rest of the time it's bang on. Is this the thermostat? Changed the temp sender two years ago to cure the fault of it working intermittently.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline new to vw
Re: Double check. Temperature.
« Reply #1 on: 24 September 2010, 08:18 »
I wouldnt worry about it bud....when you are on the motorway more air is going through the rad so it is cooling slightly quicker, hence you are getting a slightly lower temp reading...... :grin: :grin:
5 door 1.8t AUM
Offline Big Tone
« Reply #2 on: 24 September 2010, 08:46 »
Thought that, but it doesn't happen all the time.
Could this affect fuelling etc?
Offline T_J_G
« Reply #3 on: 24 September 2010, 08:52 »
This is your thermostat as mentioned in about 1000 other posts. Get it changed.
Should sit bang on 90 all of the time once it's warmed up.
Offline Big Tone
« Reply #4 on: 24 September 2010, 09:12 »
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #5 on: 24 September 2010, 21:42 »
Exactly as tim states  :wink: if you replaced the cts then your next job should be a genuine oem thermostat and some new G12++ too as its nearing the colder weather a car that doesn't get up to the optimum running temp will use a little more fuel
2000 Mkiv GTi 1.8T AGU
Offline ade_aidy_ady
« Reply #6 on: 24 September 2010, 23:10 »
Hey my car is doing the same so i changed it for a new temp sender. Sits on 90 now and same thing drops slightly on motorway . . . Tho When i log vagcom the group for coolant temp over a good journey it only gets to high 70's . . . . Never gets to 90 as shown on dial in car. . . Any ideas ?
