Author Topic: Blue Smoke on Startup  (Read 2003 times)
Offline technics
« on: 24 January 2005, 23:49 »
Hey guys, pretty new here, had my 1991 Golf Clipper for 6 months now, its not been on the road yet as im sorting a few bits and bobs for summer  :smiley:
Anyway, hopefully someone will be able to help me.
The problem I have is, my car pumps out a cloud of blue smoke on startup, but only on startup, and usually only if it hasnt been used for a day.
It was fine when I bought it, and it only started smoking after I used an engine flush.  :sad:
Oh and I also get a top end rattle now, which usually dissapears as the engine heats up.
Any idea's how to fix it, and what do I need to buy/change.
Thanks
Renault Alpine GTA Turbo
Mk1 Golf Clipper
Offline richandhazel
Re: Blue Smoke on Startup
« Reply #1 on: 26 January 2005, 10:24 »
That sounds like your valve guide oil seals are leaking/worn. I recently did Hazels Audi without removing the head. Only took a couple of hours :smiley:
Doesn't sound like yours are too bad just yet, but they will get progressively worse.
Offline carrie
  • i can see into your soul and its not good
« Reply #2 on: 26 January 2005, 12:09 »
also the rattle could be worn valve lifters when the oil flush went through it it could of shifted the sludge which was helping to keep it sealed.
i am assuming here that the clipper has hydrolic tappets, rich is that right?
SAY YOU LOVE SATIN?, NO SATAN, ITS SATAN
« Reply #3 on: 26 January 2005, 12:14 »
Yeah 91 will be hydraulic. As Carrie says, the oil flush has probably shifted some muck and its now causing the lifter to leak down through the valve guide oil seal, hence oil on start up and rattly lifter. Also, just a thought, if you did a flush, I presume you have now done an oil and filter change. Have you fitted an oem oil filter with the NRV fitted?
Offline Bullitt
« Reply #4 on: 26 January 2005, 22:06 »
Yeah definately the valve stem oil seals!!
When you have the head off also check the guides and valve stems for wear!!
Offline technics
« Reply #5 on: 27 January 2005, 19:07 »
I presume NRV stands for Non Return Valve ??? If so, some one else mentioned this, although Im not sure.
Yep, i did a full oil and filter change, I got the filter from Eurocarparts, i think its made by HENGST ?????
I'll buy another if this helps ???
Mk1 Golf Clipper
« Reply #6 on: 27 January 2005, 19:58 »
Leave that with me a moment, I'll ask Stuart from Eurocarparts in Leeds.
« Reply #7 on: 28 January 2005, 10:46 »
Probably not necessary. Have a look at Stuarts reply here:-
http://www.golfgtiforum.co.uk/index.php?topic=16874.new#new
