Author Topic: GTI Turbo misfire issues  (Read 16438 times)
Offline zorg86
« on: 23 September 2010, 20:46 »
Hi people
New member here problems with my car, basically change plugs etc due to misfire not solved, bought new coil tried each one not solved.
Took car into garage today showing cylinder 3 missing just wondering if this could be the igniton amplifier module at fault?
As I have been reading and the garage can't find out and are saying it may need full re wire and ecu.
Any help or advice appreciated.
Offline vwfiend
Re: GTI Turbo misfire issues
« Reply #1 on: 23 September 2010, 21:11 »
A full rewire is a little extreme! Take it to a VW specialist mate. What is the engine code?
Offline richw911
« Reply #2 on: 23 September 2010, 21:22 »
AGU engine?
 99% the ignition amp has failed  :wink:
http://forums.audiworld.com/showthread.php?p=1535031
Offline zorg86
« Reply #3 on: 23 September 2010, 21:24 »
Yes AGU engine I thought that when the said the wiring and the ECU I just font want get raped, thing is my car is in garage still under 'investigation' should I just ring them and tell them I done research or ask for car back?
Offline richw911
« Reply #4 on: 23 September 2010, 21:30 »
I would for sure! it is a 5min job to fit!  :wink:
You can get one here :
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_1.8_2000/p/Car-Parts/Electrical-and-Lighting/Ignition/Ignition-Modules
Not sure on the quality? Personally i would get a genuine one.
Im 99.9% sure that is the fault - though dont blame me if its not!!
Please let us know the outcome :afro:
Offline zorg86
« Reply #5 on: 23 September 2010, 21:34 »
I will do and I'll ring the garage first thing see what they have say. But question is should I request for car back and yeah I know where the part is (am I correct in saying it the module on side of airbox) and I'll also be calling my local euro car parts
Offline richw911
« Reply #6 on: 23 September 2010, 21:40 »
See this also:
http://www.golfgtiforum.co.uk/index.php?topic=167204.0
Yeah i would not let them work on my car after that advice!!  :sad:
Yes get the car back and replace the part yourself - do it out side the garage all you need is a screwdriver  :laugh:
Yes its on the air box  :wink:
Offline D4VEY01
  • 1999 GTI 1.8T AGU BLACK
« Reply #7 on: 23 September 2010, 22:27 »
This must be the month for which ignition amps go on the gr8 AGU engine,Happened on mine,just over 100 quid for the part.
1999 : GTI : 1.8T : AGU : SPEC 1 R-TECH REMAP : BOSCH SUPER 4 : FORGE TIP : SILICONE TURBO HOSE KIT : 18" RS4 ALLOYS : -30MM ADJ SPAX SHOCKS/SPRINGS : FORGE 007P D/V (YELLOW) : MILLTEK CAT BACK RES 4MOTION : POWERFLEX DOG BONE BUSHES : PIPERCROSS FILTER : FORGE ACTUATOR (YELLOW) :
Offline Dewey
  • Mk4 1.8t 150 AGU (R-Tech Stage 1 190)
« Reply #8 on: 23 September 2010, 22:35 »
I would say Ignition Amplifier, Mine went last month and it took the garage a while to find out the fault
So Far - R-tech Stage 1 Re-Map 190hp 225ftlbs, Forge 007P DV, Forge Silicone TIP, Pipercross Panel Filter,  Powdercoated Anthracite Montreal IIs, Custom Cat Back.  Shopping List - Coilovers, Hubcentric Spacers, Front and Rear ARB, Big Brake Set-Up...
Offline james2
  • No scammers please.
« Reply #9 on: 24 September 2010, 00:58 »
mine hasnt gone yet ,iv owned it over 2 years..touch wood :sad:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
