Author Topic: MK3 Cabrio and VAG-COM result. Immobilizer, brief cutout on motorway.  (Read 1037 times)
Offline garethcab
Hi all,
I've had my MK3 Cabrio for a few months now; it's a 1995 with 92k on the clock.
It's running ok, apart from every so often it will cut out very briefly when on the motorway. Nothing major, just shocks you a little. I've replaced the distributor cap and arm as it was a bit tired.
I also pulled some codes of with vag-com
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01: Engine
   Controller: 037 906 025 A
   Component: SIMOS 4S           1823
   Coding: 00000
   Shop #: WSC 00000
1 Fault Found:
00625 - Vehicle Speed Signal
            16-00 - Signal Outside Specifications
Readiness: N/A
Address 03: ABS Brakes
   Controller: 3A0 907 379
   Component: ABS     ITTAE 20 GI V00
   Coding: 03604
   Shop #: WSC 00672
1 Fault Found:
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
            35-10 - - - Intermittent
Skipping Address 15-Airbags
Address 25: Immobilizer
   Controller: 1H0 953 257 B
   Component: IMMO VWZ3Z0S0085918 V00
   Coding: 09600
   Shop #: WSC 00005
1 Fault Found:
00546 - Data wiring faulty
            27-00 - Implausible Signal
End   --------------------------------------------------------------------------------------------------
I'm not too worried about the first two as I can fix those, but I’m interested by the latter Immobilizer one.
It has an aftermarket alarm which I don’t used and is switched off. I tried switching it on but it just shrieked at me, lol
How does the immobilizer work on these?
thanks
