Kind of... You screw an adaptor that keeps a high air pressure in the cylinder (with the help of an air compressor), meaning it holds the valve tight against the cylinder head. This allows you to compress the valve spring and get the 2 half moons out, allowing you to remove the valve springs to access the valve stem oil seals. It's a camshaft cover and camshaft off job, and obviously the tappets off too.
