Author Topic: before and after...  (Read 33295 times)
Offline tsr_adi
before and after...
« on: 22 September 2010, 21:15 »
About a month ago...
Today...
Offline tsr_adi
Re: before and after...
« Reply #1 on: 31 October 2010, 17:12 »
Well not a lot has happened to this since those pics.....
Oh hang on, maybe there has! I bought a pre 90 spec donor gti 8v and converted my jade green GL to PB power! Had plenty of mishaps and problems along the way believe me, but its all done and complete now, apart from I still have the disc rear beam with ARB and a 16v MC to fit, then thats the brakes and handling dealt with.
My main reoccuring issue is a bad earth causing it to blow no less than 4 ECU's so far! After the 1st 2 I managed to sort the problem out by adding various new earths here and there, then after the 3rd ECU she fired up and I drove it home from my garage. Good times. Apart from the clutch slipping like hell (which was my own greasy fingerprints so my own fault, it'l cure itself). I found the exhaust manifold gaskets leaking quite badly so I replaced those with the inlet mani gasket too, and while I was at it I fitted the vacuum pipe through the bulkhead for the MFA to work correctly. While it was in bits I made a huuuge fcuk up and flicked the ignition on whilst the earth leads were off, thus blowing another ECU  :rolleyes:
So after refitting everything and buying a 4th ECU, all is not good here as it still has no fuel pump or spark. Did put it up for sale as I'd given up, but no1 seems to want it and I just don't know what else to do now :(
Anyways here it is rocking a matt black bonnet off the donor car as my jade green one is scratched to hell (probs from me piling front crossmembers on it when it was in the garage)
Offline SoundillusioN
« Reply #2 on: 01 November 2010, 00:28 »
wow.... great work  :shocked: .... shame you didn't document the work on here (pics)..  Damn you were unlucky with the electrics, hope thats the end of that for you now then! bet its a nice drive.....  :cool:
Offline lewis1641
  • stuck in the 90's
« Reply #3 on: 01 November 2010, 10:53 »
good work (nearly!)
dont sell it! you are so close to having it right.
dont suppose you still have the donor car do you? i need some bits and bobs off my doors. handle covers and bolts etc.
Offline tsr_adi
« Reply #4 on: 01 November 2010, 11:34 »
The whole thread is here
http://www.vwgolfmk2.co.uk/modules.php?name=Forums&file=viewtopic&t=27059
I haven't got the donor car anymore but I've still got a whole load of bits left over. PM me a list of exactly what you need and I'l have a looksie mate. It was a great buzz driving it round the block, even though it wouldn't put the power down with a slippy clutch. Just gutted it won't start again. Its been sat outside for weeks now cuz I'm skint (still out of work  :embarassed:) and I just can't afford to keep buying ECUs and I've done everything I can with the earths  :cry:
Offline lewis1641
  • stuck in the 90's
« Reply #5 on: 01 November 2010, 12:05 »
i wish i could help mate. i have an ecu but obviously dont want to risk it getting blown.
my mate works with ecu's - i'll see if his contacts have any old spares.
do you know what has blown inside? it might be something simple that can be replaced like a resistor or a chip or something?
Offline tsr_adi
« Reply #6 on: 01 November 2010, 22:34 »
tbh I'm not even sure the last 2 have blown, the 1st one was completely obvious but the 2nd one wasn't, so I tried repairing the 1st one with bits inside the 2nd one. I'm not sure if revised ECUs (ending in DB, my earlier one ends in "N") from 90 spec cars work, as the 2nd one was a DB code, but didn't work, then after I sorted the earths I fitted an earlier N code and it worked. Then when I blew that one I sorted the earths out again, fitted a later DB code ECU and it still won't work. Just seems a bit coincidental to me! I've been told that fitting a revised one shouldn't make a difference, but they do look diffrent inside, with more chips and transistors inside.
I wouldn't want to try anyone elses ECU in case I spoil their day too  :grin: But I really need to try these last 2 in another car, shame you havent got the digifant in and running yet  :smug:
Offline tsr_adi
« Reply #7 on: 04 November 2010, 15:20 »
looks like I'm gonna have to break this  :sad:
Offline tsr_adi
« Reply #8 on: 19 November 2010, 20:01 »
Right after a tense few days of the car being on ebay.....
No-one wanted her!  :huh:
I cannot bring myself to break her after all my hard work, so I'm gonna get the 306 gone for whatever I can get for it and buy yet another ECU (will be the 5th) and hope she lives again! I am going to sell off a lot of the spares I wanted to keep though, seeing as times are hard  :sad:
Offline lewis1641
  • stuck in the 90's
« Reply #9 on: 19 November 2010, 20:23 »
Good to hear that!
Got any coilovers?
