Author Topic: cam postion sensor  (Read 1009 times)
Offline opel
cam postion sensor
« on: 22 September 2010, 17:45 »
just had a freind ring up he has his engine mangement light keep coming on it kept coming up with cam postion sensor so he replaced it with a new one yet it still keeps flashing up with it after replacing the sensor. it on a 1.4 03 plate golf if anyone has got any clue to what to do next
Offline madmk4
Re: cam postion sensor
« Reply #1 on: 22 September 2010, 18:58 »
has he recently had the cambelt changed
Offline opel
« Reply #2 on: 22 September 2010, 20:00 »
yer but that all timed up properly checked and double checked
Offline james2
  • No scammers please.
« Reply #3 on: 22 September 2010, 23:38 »
you need to delete the code ...mine did the same ,strange it was after having new timing belt, i thought the timing was out ...but just the sensor  :smiley:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline 2001gti4
« Reply #4 on: 24 September 2010, 16:38 »
Mine was done by Mr Clutch and they'd put it back together a tooth out. Reset the fault and see if it reappears, if it does you may need to triple check  :smiley:
My Golf is dead but at least I have this....
Offline madmk4
« Reply #5 on: 24 September 2010, 20:24 »
mine got done b4 i bought mine mines intermitent so dont know wether it is the sensor . been like it since oct
