Author Topic: Injectors upgrade for AGU  (Read 8121 times)
Offline mendonza
« on: 22 September 2010, 03:49 »
hi, i need to know asap if this injectors will upgrade my stock ones. They belong to a VOLVO 2.3L and they are 30lb
They don't have many info of it so i need to ask you guys if trough the photo they will fit my 1.8t GU engine.
Thank you
Offline littco
Re: Injectors upgrade for AGU
« Reply #1 on: 22 September 2010, 08:44 »
Pretty sure that saab red tops (Bosch) which are rated at 32lbs at 3psi are the ones you need. They may be the same as the volvo ones you mention.
Offline mendonza
« Reply #2 on: 22 September 2010, 08:50 »
hi, thank you for your answer. The AGU stock injectors are EV6, i don't know if an EV1 will fit. Most of the injectors available on ebay, are EV1. Those red tops from Saab will fit on the  AGU? I already have a 4bar FPR to upgrade my 3bar stock FPR.
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #3 on: 22 September 2010, 09:02 »
calibra turbo yellow injectors and saab reds can be used, both flow more than stock injectors. however running just a 4 bar fpr with theinjectors wont be enough. You really need to upgrade the stock fuel pump to something like a walbro 225 inline pump
Offline mendonza
« Reply #4 on: 23 September 2010, 12:47 »
Are you saying to use this one too? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270618432016&ssPageName=STRK:MEWAX:IT
Offline Devilz
  • Cruisin is not a crime
« Reply #5 on: 23 September 2010, 12:50 »
can I ask why you are upgrading injectors?
Offline mendonza
« Reply #6 on: 23 September 2010, 12:52 »
Sure. I am collecting all the necessary material for the upgrade i am planning for my gti. I already have many stuff. When i have all the material, i'll upgrade it. I can'd pay for all this things in 1 shot lol, the money doesn't grow my friend lol :grin:
Offline Devilz
« Reply #7 on: 23 September 2010, 13:04 »
I know it doesn't, are you going for ko4??
Offline mendonza
« Reply #8 on: 23 September 2010, 13:05 »
Yes :grin:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #9 on: 23 September 2010, 16:18 »
Do you really need to upgrade injectors for k04 ?? cant you just run the standard ones at a higher duty ??
