its even easier on a 16v than an 8v, exactly the same procedure but you dont need to worry about thye intermediate shaft or dizzy timing. the belt needs to be done up a bit tighter than an 8v, but the later abf has a self adjusting tensioner so this is taken care of. it has a pair of arrows on it which move as you tighten the tensioner, you tighten the tensioner till the arrow moves as far as it can go, then loosen it till the arrows line up, simples.
you'll need a proper timing belt tensioner tool though, the old bodge way of using a bent fork, allen key or bent circlip pliers wont work on these as the 2 peg holes are not deep enough
if it has the earlier tensioner, you just tighten it till you can get around a 45 degree twist on the belt
early up to ABF020922:
http://www.vwspares.co.uk/product_info.php?products_id=566late abf from ABF020923:
http://www.vwspares.co.uk/product_info.php?products_id=456late tensioner link even has a link to the right tool
you can convert between the tensioner types by changing the tensioner stud and nut too if you want
