Author Topic: What do you hate most about your mark 2?  (Read 18033 times)
Offline X4MGS
  • VAG Parts SNOB!!!
Re: What do you hate most about your mark 2?
« Reply #40 on: 21 September 2010, 22:35 »
Right person wrong quote...  :grin:
The seal must "seal" something else they wouldn't fit one and call it a SEAL  :tongue:
Get some wire down the holes to unblock 'em then...
and its a 1.3 that wont do any better than 33mpg  :angry:
Heavy car and small engine... I get better out of my Digi 8V... :wink:
hang on, it isnt the seal that stops the leak is it? I thought it was more to do with the drainage channels or whatever theyre called?
I think you quoted the wrong person :D
And yes, you're pretty much right, there can be a gap all round and it can still not dribble on your head as long as everything else is in working order. Mine was missing a big metal bit that allowed the water to drain out the rear properly - so it would continually dribble on me!
For More Info Click To See;
Offline Ben Lessani
« Reply #41 on: 21 September 2010, 22:37 »
What do these seal
The seal is made of felt, not rubber, it only really seals against wind - it happily absorbs water and lets it flow right through.
Offline Haribo!
« Reply #42 on: 21 September 2010, 22:39 »
And onto my head
Offline Ben Lessani
« Reply #43 on: 21 September 2010, 22:41 »
And onto my head
Check you've got all the parts, in the diagram below, fitted. Mine was missing #9
Offline Haribo!
« Reply #44 on: 21 September 2010, 22:52 »
I know im good al the way down to part 25, cause i took it all apart to change 3 and 3a cause i thought they were the problem i had before but it turned out that someone even less mechanically knowledgable than me put the deflector arms onthe wrong sides upside down.
Offline bundy
« Reply #45 on: 21 September 2010, 23:06 »
that ive had it over 2 years have only driven it back from getting it MOT'd then its sat on my drive getting rusty and unless i get a massive pay rise any time soon it stay like that   :cry:
Offline cняis
« Reply #46 on: 21 September 2010, 23:21 »
To cure a leaky sunroof:
Tools Required:
1x tube of RTV silicone
1x phillips screwdriver
Method:
Seal the outside of the sunroof with the RTV silicone. Unscrew and remove the sunroof winder handle. You are now leak free for under £5
You can thank me later chaps.
Offline Mitching
« Reply #47 on: 21 September 2010, 23:35 »
Yeah, Mastic that bad boy up!  :cool:
Offline myvr6isarocket
« Reply #48 on: 21 September 2010, 23:52 »
What do these seal
Isnt he thumping one into Heidi Klume?
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #49 on: 21 September 2010, 23:59 »
Note To Self; Never Buy a car from a guy called cняis...
:laugh: :laugh: :laugh:
Tools Required:
Method:
