Author Topic: Seat runner guide help  (Read 5636 times)
Offline twistedblack69
  • Proud mk2 user and abuser
« on: 20 September 2010, 19:54 »
So the Golf failed it's MOT on loose front seats (as well as other things) but when I try and put the runner guides on and put the seat back on, the runner guides pop off. Is this a clue that the guides are shot, or am I not putting them on right? Was thinking about gluing them on lol but figured I'd ask on here first
Offline cняis
Re: Seat runner guide help
« Reply #1 on: 20 September 2010, 20:07 »
shouldnt have failed cos the seat is still secure (its not coming out of the rails is it?)
mine passed with the plastic guides hanging out, the passenger seat was worse. prised them back in and its been fine since.
GSF sell them though, and they cost pennies so get some new ones  :tongue:
Offline mk2bal
« Reply #2 on: 20 September 2010, 21:23 »
I got the same problem. Noticed it when goin round roundabouts leanin all over the show. My 1 actually clips into place firm, but as soon as u slide the seat back in it pops off?
Offline cняis
« Reply #3 on: 20 September 2010, 21:37 »
HEre you go, just found them on GSF
863VG0750           SEAT RUNNER CLIP-OUTER           G2           1.20
863VG0760       SEAT RUNNER CLIP-INNER       G2       1.55
Offline Ben Lessani
« Reply #4 on: 20 September 2010, 22:35 »
The old ones tend to fall out of place quite easily.
There is a little retention clip in the middle - which is essentially just a pin that holds in a slot on the runners, but this gets worn and stops it holding in place.
New ones are quick and easy to fit, its always tempting to grease the guides, but there's a big risk it will dirty the carpet - so use it sparingly, thin lubricants like WD40 tend to be a big naff for stuff like that.
« Reply #5 on: 21 September 2010, 10:12 »
Yea it didn't even come up as an advisory last year  :embarassed: :embarassed: no it's not coming out of the rails, just rocks back and forth
« Reply #6 on: 21 September 2010, 10:20 »
i find even new ones can pop off the seat, what i do is bend the middle bit inwards as far as i can, gives it a bit more springy ness on the clip to hold it to the legs. as above a bit of lube helps a liot too but go easy on it and dont bother using thin stuff. especially wd40 which is a water dispersant not a lube  :grin:
Offline cняis
« Reply #7 on: 21 September 2010, 19:31 »
try white spray grease (ooh err) which is thick, can be used on all sorts including hinges, cables etc
Offline daniel-1986
« Reply #8 on: 21 September 2010, 19:54 »
i put brand new runners on my seats and they still rock back and forths
Offline cняis
« Reply #9 on: 21 September 2010, 23:23 »
something not quite right there then, i popped my original ones back into the feet and it stopped the movement  :undecided:
