Author Topic: Unable to open N/S rear door  (Read 4038 times)
Offline richandhazel
Re: Unable to open N/S rear door
« Reply #10 on: 21 September 2010, 13:29 »
I'll have another try when Hazel gets back with the car...........I reckon I need to try and find a way to let the right hand lever rotate past the white plastic lever/bulk. I may be able to get at the metal part and bend it to clear the plastic, not sure without looking.
Thanks for the input.........I'll let you know how I get on.
Offline Purely VAG
« Reply #11 on: 21 September 2010, 14:43 »
Had exactly same problem pal. Had to remove doorcard from inside which is "fun".
I then used a pry bar upagainst the lock mechanism and whacked it with a hammer on the lever to open it.
I also had it on another car which i simply banged the door from the outside with my hand and that opened.
Either way........
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
« Reply #12 on: 21 September 2010, 14:54 »
Well, I can't get at the part of the mechanism that you're on about Chris :cry: It's right against the door skin.
I've tried the banging on the door technique whilst unlocking.......no joy there.
Out with the pry bar :shocked:
« Reply #13 on: 21 September 2010, 15:12 »
Still won't budge :cry:
Just looked at the manual and its not an MOT failure. The front doors must open from inside and out, the rear ones must latch closed............it does that all right :shocked:
I think we're going to live with it and I'll put it back together...........damned inconvenient :angry:
Offline MaXXeH
  • Golf MK5 GTI
« Reply #14 on: 21 September 2010, 15:15 »
weld both the doors shut and make it a 3 door :P
« Reply #15 on: 21 September 2010, 15:21 »
I'll leave it all apart for now in case someone comes up with a magic solution :huh:
Chris, if you do get a chance to look at yours can you let me know if you think there is anything that might be preventing it from manually unlocking. It looks like there is a motor as well as the microswitches in the module so I'm wondering if the motor hasn't reached a full position and the microswitch isn't talking to the convenience unit :undecided: That in turn may be preventing the mechanical side from operating :undecided:
Going to dig out the wiring diagrams and peruse them in the meantime.
« Reply #16 on: 21 September 2010, 15:23 »
Yeah......could be worse I guess. At least the kids can still pile in from the N/S passenger door :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #17 on: 21 September 2010, 15:37 »
if you go into measuring blocks under the CCM in vagcom you can see what state the 4 microswitches are in, but it seems more like mechanical failure to me.
« Reply #18 on: 21 September 2010, 15:48 »
I think you're right...........clutching at straws really.
Not exactly sure what that motor does but its pins 1 & 2 on the connector so I'm tempted to try putting 12V through the pins and see if anything moves.......can't really make anything worse as long as the convenience unit is disconnected.
I could try VAGCOM tomorrow.........if only out of curiosity. Lock all the doors and compare the readings. I might be lucky and it'll be microswitch 4 which is on the mechanical side and easy to get at the wiring :undecided:
« Last Edit: 21 September 2010, 15:51 by richandhazel »
Offline topher
  • Administrator
  • fully functioning
« Reply #19 on: 21 September 2010, 15:52 »
no4 only tells the ccm that the door is open or closed, it's the one that most often fails but it shouldn't jam the door shut. Doesn't hurt to have a play though!
