Author Topic: MK3 GTi  (Read 1497 times)
Offline Ronnievdub
MK3 GTi
« on: 23 January 2005, 19:13 »
hello fellow dubbers.
just started using the forum so I'm gonna start with a query.
I need help, my MK3 golf GTi is playing up. it doesn't start very well when its cold and stutters when it does fire up. When i start driving it lags when i put the foot down then lurches forward. It does this in every gear. Also when its idling it cuts out and to prevent this Ive gotta sit with my foot on accelerator to keep it running.
Its been into the garage and no one is able to tell what could be wrong with it. Ive got my suspicions it could be the throttle body but I'm not certain.
Any advice would be greatly appreciated.
Ronnie
mrwotto
Re: MK3 GTi
« Reply #1 on: 23 January 2005, 19:18 »
Try cleaning the throttle body mate, do a search on the forum for how to do it, if you cant find it drop me a pm or post back here and I will see what I can dig up for you.
Paul
Offline Ronnievdub
Re: MK3 GTi
« Reply #2 on: 23 January 2005, 19:28 »
cheers mate
ive had the throttle body cleaned before although it wasnt an extensive clean. it seemed to run better for a bit but the problem has reared its ugly head again.
Ive also had the throttle plate reset as two faults showed up on the diagnostics. it stopped the cutting out problem when it was idling.
i was also told to clean out the airflow meter as it may be clogged up with dust and dirt.
Im keen to get it sorted quick coz ive to put it in the bodyshop next month for a heap of mods to get done (smooth boot lid, colour coded interior and a set of merc AMG wheels which sit nicely under the arches.)
International in May so it will be on show
Ronnie
