Author Topic: golf starting  (Read 1414 times)
Offline col
golf starting
« on: 15 September 2010, 13:30 »
when its been heavey rain my gti 8v takes a bit of starting when started for first time that day! but once started it starts first time every time all day!
this only happens when its rained heavey what could it be? thanks col
Golf Anniversary Alloys - bbs rxII - 16's wanted
Offline dave_g
Re: golf starting
« Reply #1 on: 15 September 2010, 17:17 »
Could be moisture on the electrics, give the leads, dizzy and coil a spray with WD40 an see if it still happens. Have a good look at the coil to see if there are any cracks too.
I would imagine after a bit of driving, the heat from the engine would dry the electrics out, hence it being fine all day.
Dave
Offline polo6n222
Re: golf starting
« Reply #2 on: 16 September 2010, 07:46 »
Quote
could be moisture on the electrics give the leads,dizzy a spray with wd40
+1 my old car used to do it every time it rained
Offline harlemex
Re: golf starting
« Reply #3 on: 16 September 2010, 14:02 »
++++2 , get some new leads.
Offline col
Re: golf starting
« Reply #4 on: 16 September 2010, 21:11 »
so get new lead's and a dizzy how much you recon that will set me back?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: golf starting
« Reply #5 on: 16 September 2010, 22:14 »
Possible coil pack !!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline fozziie
  • psn: fozziie
Re: golf starting
« Reply #6 on: 18 September 2010, 16:31 »
mine does this. its not the leads or dizzy, i strongly suspect its the coil...but i cant be arsed to check it.
easiest way to find out for sure is when its dark, with your engine running, spray a mist of water over the electrics, look for any arching or sparking.
Offline col
Re: golf starting
« Reply #7 on: 27 September 2010, 12:51 »
how much are they roughley?
