Golf mk4
Wazzzer
can a whistling turbo be fixed
Topic: can a whistling turbo be fixed (Read 1496 times)
ggggolfgti
GTI forum regular
14 September 2010, 23:07 »
if a turbo is making a high pitch whistle and not boosting properly can i be saved??
249 bypass, ths fr3 engine mounts, S/S decat, 2.5'' straight through exhaust, induction kit, forge split r, coilovers, 18'' alloys, much more in the pipeline
topher
Administrator
Serious forum addict
fully functioning
Re: can a whistling turbo be fixed
15 September 2010, 01:03 »
if you're sure it's not a cracked manifold or leaking gasket, then the turbo needs looking over. I'd check the compressor wheel first (easiest to get to and most common) then the turbine/wastegate.
Joe1988
15 September 2010, 17:21 »
Don't know a great deal about turbos so cant comment on wastegates etc but I work on jet turbines and a damaged compressor wheel would definately cause tht on them so thts where I would look.
Golf mk4
Wazzzer
