Author Topic: driveshafts??  (Read 12756 times)
Offline Mrwebster
driveshafts??
« on: 14 September 2010, 22:06 »
Hi, well ive come to replace my drifeshaft and theyve sent me one the loks differnt but assured me it would fit,
so rather than spend 2 hours on my back trying to struggle id thought id post it on here see if anyone could re assure me or confirm it will fit,
are 1+2 the same? will the longer bolts go directly into the gearbox output flange? replacing the shorter ones with using the spacer?
have serched for info on this and couldnt find any so sorry if its already been posted,
thanks for any help,
Golf GTI turbo (230hp)  mx5 / eunos roadster 120bhp Reliant rialto modified (49hp)
Offline vwprime
Re: driveshafts??
« Reply #1 on: 14 September 2010, 22:12 »
Funny you should bring this up mate as another forum member has had the same thing.
Have a read of this post and see what you think  :smiley:
http://www.golfgtiforum.co.uk/index.php?topic=166455.0
TRANSFORM, & ROLL OUT!
Offline houston
Re: driveshafts??
« Reply #2 on: 15 September 2010, 12:33 »
as long as the bolts fit then the shaft will fit fine, its just some models need the cv further out for clearance
Offline 1688bran
Re: driveshafts??
« Reply #3 on: 15 September 2010, 12:57 »
The top on is from a 6 speed box car and the old one is from a 5 speed box car , but it can be done using a longer bolt but is a hassle to find the right size and thread size ... it be easier to just get a 5 speed shaft ... I got a spare available if u interested !
Offline houston
Re: driveshafts??
« Reply #4 on: 15 September 2010, 14:18 »
no it isnt, m10x48, thread pitch is still the same, its actually off a few different models that need the extra clearance of a longer cv.
the 6 speed auq uses a hub bolt and not a nut so its def not a 6 speed shaft
Offline 1688bran
Re: driveshafts??
« Reply #5 on: 15 September 2010, 14:29 »
2wd 6 speed is different from the 4wd 6 speed !
Offline houston
Re: driveshafts??
« Reply #6 on: 15 September 2010, 14:44 »
that drive shaft is not off any 6 speed car, 2wd and 4wd use the same front shafts iirc.
« Last Edit: 15 September 2010, 14:56 by houston »
Offline houston
Re: driveshafts??
« Reply #7 on: 15 September 2010, 14:53 »
ok, my apologies, the bolts are am10x52, part no 105 234 01 from vw
or m8x48 893 407 237, im struggling on etka to see the differences between the 2 listed driveshafts.
is there any part no's on it and i can check, i think its off a 4 motion if the bolts are m10s which will still work with your car
« Last Edit: 15 September 2010, 15:06 by houston »
Offline 1688bran
Re: driveshafts??
« Reply #8 on: 15 September 2010, 15:18 »
just look on the etka for audi tt quattro it will be listed on there !
Offline houston
Re: driveshafts??
« Reply #9 on: 15 September 2010, 15:25 »
why? the tt will be different shafts surely, the golf 4motion shaft is listed but looks identical to the fwd except smaller bolts to hold the cv onto gearbox
