Author Topic: MKIV Golf Inner CV Joint  (Read 11477 times)
Offline number1bassman
« on: 13 September 2010, 11:44 »
Quick question guys,
My inner CV Joint has gone and JORDYGTI has sent me a new one, but the inner joint is different.
He says it will fit but I can't see how.  Am I being thick (Which has been known)??  :laugh:
Here's a picture of two driveshafts (Not mine).
The one that is on my car is like the one on the left, and the one he's sent is like the one on the right.
Will they interchange?
THANKS IN ADVANCE!
Re: MKIV Golf Inner CV Joint
« Reply #1 on: 13 September 2010, 11:45 »
Sorry, just better add, the inner joint has gone on my car and Jordy has sent me a complete shaft!  Not just a joint sorry!  :rolleyes:
Offline vwprime
« Reply #2 on: 13 September 2010, 11:52 »
The drive shafts are diffarnt left to right in leanth and thickniss. did you say what side or is it just the bearings you are worred about?
TRANSFORM, & ROLL OUT!
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #3 on: 13 September 2010, 11:53 »
the one on the left looks like a drivers side driveshaft and the other passenger side. Drivers side is normally thicker.
Offline vwprime
« Reply #4 on: 13 September 2010, 11:59 »
I dont know if this helps or not but this is what my left drive shaft looks like on a 1999 AGU Golf
« Reply #5 on: 13 September 2010, 12:03 »
Hi guys,
The one he's sent is the right length, but the mounting point to the gearbox is different!  It's the one on the right not the one on the left like my car and the fella above who posted his car with the box out!
Offline houston
« Reply #6 on: 13 September 2010, 13:55 »
its ok, they are interchangeable
« Reply #7 on: 13 September 2010, 14:39 »
How?  The bolts are different!
I guess I'd have to change the mounting flange from the gearbox as well?
Offline Grand Master Patch
« Reply #8 on: 13 September 2010, 18:21 »
What gearbox do you have? 02J?
« Reply #9 on: 13 September 2010, 19:26 »
I guess so, the engine has been changed and the box at some point but it looks like the ones posted above!
I'm so gutted! It's only a cv joint and I've bought a driveshaft that I'm told will fit but no one will tell me how to make it fit and Jordy isn't talking to me either now! Hope I haven't upset him?
