Author Topic: Twin 40's.....  (Read 1211 times)
Offline moonsta
Twin 40's.....
« on: 22 January 2005, 07:39 »
 :embarassed: sorry to sound stupid,but if i fit twin 40's on my gti and remove the old injectors,what do i put in the holes that are left to fill em up?? have never seen a car up close that's converted so not had a chance to look,thanks and no i'm not blonde!!!!  :laugh:
Drives '96 Polo 6N and '85 Mk Golf Gti...
Offline mk1
Re: Twin 40's.....
« Reply #1 on: 22 January 2005, 10:11 »
On the later injected cars the injectors are in the manifold, so when you change to 40's the manifold you have to use has no holes.
Steve.
Offline moonsta
Re: Twin 40's.....
« Reply #2 on: 22 January 2005, 10:22 »
 :smiley: i'm actually thinking of doing it to a 1990 audi 2.0 which is going in my jetta,so will check it out.thanks :grin:
Offline maximous
Re: Twin 40's.....
« Reply #3 on: 23 January 2005, 15:21 »
if your doing it to a 2.0l then i would go with 45s for the fueling
Offline moonsta
Re: Twin 40's.....
« Reply #4 on: 23 January 2005, 15:48 »
 :smiley: thanks for that,i haven't sourced any carbs as of yet bt will bear that it mind.I have found that Demon Tweeks do the manifold for ?113:00 and the throttle cable too.I should be able to pick up a good pair of 40's for about ?200.........ta :smiley:
