Author Topic: alternator  (Read 1306 times)
Offline marcogolfo
  • Freelance Web Design, Logo Design etc email me
alternator
« on: 21 January 2005, 18:02 »
had alternator tightened up and it sounds dead winy, you know like an electric sort of whining sound.  Any ideas?
Its doing my head in
laserblaster
Re: alternator
« Reply #1 on: 21 January 2005, 19:46 »
you have to tighten the belt up at the correct tightness!
too tight and you will wear the belt out quicker and also wear out the alternator bearings, and water pump!!
i'd doubt if it affects the crankshaft!
if its too tight it could be the belt which is whining!
if its making a noise then its too tight!
Offline marcogolfo
Re: alternator
« Reply #2 on: 22 January 2005, 14:31 »
cheers mate so you reckon to slacken that bugar of a little eh?
also oI have a knockin noise, ya reckon this could be related to it? cheers
Offline richandhazel
Re: alternator
« Reply #3 on: 26 January 2005, 05:02 »
Yeah if you overtighten the belt you're going to load those bearings and wear them out. IMO as long as the belt doesn't slip (when wet) then its tight enough. If you need to do it up too tight to prevent fan belt squeal, then you need a new belt.
Offline marcogolfo
Re: alternator
« Reply #4 on: 26 January 2005, 10:43 »
cheers
