Author Topic: Does this look familiar! And rough idle  (Read 2406 times)
Offline mikemk4gti
« on: 11 September 2010, 20:55 »
Changed the upper breather pipe on my latest golf today, then found another hose split, it's the one behind the dipstick that goes onto the bottom of the inlet manifold. I've repaired that too now, but the car doesn't idle too well, it ticks over but every few seconds it's like it misses on 1 cylinder, any ideas?? It drives fine.
It's a 1.8t AUQ btw.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Does this look familiar! And rough idle
« Reply #1 on: 11 September 2010, 20:57 »
AUG? Anyways you need it on VAG COM mate, you can do a misfire count to see if it really is missing
Offline mikemk4gti
« Reply #2 on: 11 September 2010, 21:03 »
Edited that to AUQ, I've checked for faults with vagcom and there's none stored
Offline new to vw
« Reply #3 on: 12 September 2010, 00:17 »
Mine does that for the first 100 yards then is ok....its like one of the plugs isnt firing.....Dont think VAG COM can tell if its the plug.....it can only tell if the coil is naff.....Have you disturbed the coils at all, if so they might need to be pushed back on to the plugs :wink: :wink:
5 door 1.8t AUM
Offline kuvalee
  • Approved vag painter since 1999
« Reply #4 on: 12 September 2010, 18:00 »
I changed the same pipe on friday still didnt run right so had another look arround saw that the bottom of the dip stick had snapped all the way arround so replaced it and put it on the 1535 at vw and it said that the fuel mix was lean so re set it and heypresto all sorted and feels faster now!!
Offline mikemk4gti
« Reply #5 on: 12 September 2010, 19:57 »
reset it?? I have vagcom, can I reset something, and if so how?
