Author Topic: Oil temp on MFA  (Read 1550 times)
Offline philadams16V
Oil temp on MFA
« on: 21 January 2005, 16:31 »
Just had my cambelt changed and when I got my car back the oil temp on the MFA doesnt work anymore.  All the other readings are fine.  Was wondering where the sensor was located, whether it may have come loose? How easy is it to fix and how do I do it?
Offline mk1
Re: Oil temp on MFA
« Reply #1 on: 21 January 2005, 19:21 »
The sensor is on the cylinder head near where the distributor is. Look for a brass sensor with a "nail" type head, there may be a loose wire floating around looking for a home :wink:.
Steve.
Offline Mr Blue
Re: Oil temp on MFA
« Reply #2 on: 21 January 2005, 19:34 »
Steve.
I thought the oil temp was on the oil filter housing? and that the one on the cylinder head is the oil level sensor?
mix
Re: Oil temp on MFA
« Reply #3 on: 21 January 2005, 20:25 »
Sounds about right to me.  cos when my bro did it, its down the bottom of the engine!
And when you replace it, do it up f**king tight, not to tight or you f**k your sensor, cos if you dont you get a slight oil leak and your car smokes :evil:
Re: Oil temp on MFA
« Reply #4 on: 21 January 2005, 21:38 »
Quote from: Blue Mk2
As I found out recently on the 8v its on the oil filter housing, but on the 16v its in the head  :smiley:
Offline Mr Blue
Re: Oil temp on MFA
« Reply #5 on: 21 January 2005, 23:27 »
ive got the same prob too
what sensor do i change on the housing on my 8v?
Offline mk1
Re: Oil temp on MFA
« Reply #6 on: 22 January 2005, 10:07 »
On the 8v it is in the oil filter housing, look for a brass sensor with a nail type head near the oil switch.
Steve.
