Author Topic: Rhyso's 205bhp Posh Golf....Gone :(  (Read 670017 times)
Offline Sam
  • Sam I am
Re: Rhyso's 205bhp Posh Golf....and the repair bills keep coming
« Reply #1450 on: 10 May 2014, 23:18 »
So the handbrake has had a bit too much play in it lately.  Booked it into the garage for it to be readjusted.....
Phone call at lunchtime - both callipers were seized solid.  We've managed to free the passenger side but not the drivers side.  We'll give it another go and let you know but you probably need a new calliper
20 minutes later - 'we've freed calliper and went to bleed the system.  Cracked the bleed nipple to find that's knackered so we can't put it back.  New calliper is needed
Just to rub it in they can't get a new calliper until Tuesday so the car is off the road until then  :sad: Gone for a refurb item which is £80 as opposed to £160 for a brand spanker.
Seriously not impressed with the fact the calliper is shagged on a car with 77,000 miles on the clock  :angry: :angry:  I suspect the bloke who changed my rear discs and pads might have damaged it when he bled the system.....
Will need one for the passenger side at some point but that can wait.  And I've still yet to resolve my traction issues.  And I'll be needing front tyres soon  :rolleyes: :cry:
Is this a specialist garage? Anything past a B5 needs to be programmed to allow you to wind the callipers back in if they are the electric park break type. Also, they are twisty turny jobbies, they arent simple but I fail to see how BOTH could have failed.
Offline Rhyso
« Reply #1451 on: 11 May 2014, 07:00 »
No fancy electric brake on mine; just your usual piece of sh!t callipers that corrode. I had the ones on the MK4 stripped and cleaned at one point
Offline Rhyso
« Reply #1452 on: 17 May 2014, 14:04 »
Well despite the recent niggles its still quick enough to embarrass a remapped Alfa coupe diesel  :whistle: :evil: :grin:
Good job the mobile speed camera van was much further down the road  :lipsrsealed:
Offline Rhyso
« Reply #1453 on: 24 May 2014, 13:35 »
Soon have a complete matching set
Managed nearly 14k out of the F1's though the fronts spent 12k of those on the rear.........
Looks like I will need to replace the handbrake cables too as its gone back to how it was prior replacing the callipers  :angry:
Still got the random ESP issue so will be interesting to see if the new tyres will help although I doubt it
Offline Rhyso
« Reply #1454 on: 24 May 2014, 14:54 »
Offline Rhyso
« Reply #1455 on: 27 May 2014, 19:12 »
Weird ESP issue may be resolved......
Fitted another pair of UniRoyals so now have a complete set. First test passed.....
Offline Bellend
« Reply #1456 on: 27 May 2014, 22:19 »
I'll be shocked if it is the tyres but hopefully for you it is!
Where all my moneys went.
Offline Rhyso
« Reply #1457 on: 27 May 2014, 22:25 »
Well my test is to take it around a particular roundabout which prior to the issue I could do at approx 30mph and just get tyre squeel. Then I was unable to drive at over 25mph without the ESP kicking in. With the matching fronts I could acheive the former  :smiley:
Will give it some thorough testing tomorrow
Offline Bellend
« Reply #1458 on: 27 May 2014, 23:09 »
Hmm I see, thought it was kicking in on a straight line though?
The MK4 kicks in on the motorway in 6th in the rain but that's due to sh!t suspension, alignment way out and sh!t bald tyres so I don't blame it. :grin:
Offline Rhyso
« Reply #1459 on: 28 May 2014, 15:00 »
No.....i said it happened once ina straightish line chasing a VXR. I had about 10degrees of steering lock on but it was at speed
The main issue was with more steering angle at lower speeds
