Author Topic: vacuum hose  (Read 1471 times)
Offline hockeylad72
vacuum hose
« on: 20 January 2005, 22:17 »
help required again!!!
vacuum hose from back of instrument cluster where does it go to ( the hose is for the mfa)
went to my local VW dealer today they could not tell me
hope someone can help me on this one
cheers
Offline Dizzie
  • Make friends with your fast
Re: vacuum hose
« Reply #1 on: 20 January 2005, 22:41 »
inlet manifold  :cool:
Offline hockeylad72
Re: vacuum hose
« Reply #2 on: 20 January 2005, 22:44 »
where about, was previously told inlet manifold. i have looked and cannot see where it would attach.
Offline Dizzie
Re: vacuum hose
« Reply #3 on: 21 January 2005, 12:41 »
if it's a k-jet 8v then I think it was on a bunch of tubes coming off the end and going between the manifold and the scuttle panel. It comes out of the scuttle as a clear plastic tube and goes into a piece of rubber before joining the manifold.
Offline davidhawkins_78
  • Valver Bad Boy
Re: vacuum hose
« Reply #4 on: 21 January 2005, 13:37 »
On a Digi GTi it's pretty much the same - look at the tubing coming off the inlet underneath the coil area - should be a 'T' piece it connects to ...
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline hockeylad72
Re: vacuum hose
« Reply #5 on: 22 January 2005, 10:38 »
cheers guys, managed to find it. Previous owner blocked it off
sorted!!
