Author Topic: harnesses  (Read 2009 times)
Offline bosco
harnesses
« on: 08 September 2010, 09:06 »
i no this is a stupid question but i want to run harnesses in my car but where do you get that bar that goes across behind the back seats from the seat belt joints?
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
Offline Horney
Re: harnesses
« Reply #1 on: 08 September 2010, 09:40 »
Custom made usually. DO NOT use a rear strut brace as this is not designed for this puprose.
Pop into the motorsport/trackday section and have a nosey in there, plenty of info floating about.
Nick
Offline Diamond Hell
  • Opinions я Us
Re: harnesses
« Reply #2 on: 08 September 2010, 14:00 »
Why do you want to run harnesses?  Why not buy a CG-Lock for your belt? (Google it).
Done properly harnesses need proper buckets and proper mounting points around the shell, where needed.
 :grin:
Offline Horney
Re: harnesses
« Reply #3 on: 08 September 2010, 14:02 »
What's so funny about that?
nick
  • Opinions я Us
Re: harnesses
« Reply #4 on: 08 September 2010, 22:41 »
I've seen morons do it and been quite frightened about how unbelievably stupid some people can be - thinking that a strut-brace which attaches with minimal fixings to the suspension strut tops would be strong enough to restrain two people in a crash.  :rolleyes:
Offline Horney
Re: harnesses
« Reply #5 on: 08 September 2010, 22:45 »
Ah I thought you were laughing at me, ha ha. I was wondering what stupid thing I had said now.
Nick
Offline re2
Re: harnesses
« Reply #6 on: 12 September 2010, 16:56 »
is it safe to use an original rear belt fixing point? I know its only one of the 3 points used. Im guessing not really
Offline fishnchipsx2
Re: harnesses
« Reply #7 on: 12 September 2010, 20:41 »
I'd like to see what can be done on a budget in a mk1 Caddy.  But I guess I won't, cos they make sh!t track cars  :grin:
Offline bosco
Re: harnesses
« Reply #8 on: 13 September 2010, 00:21 »
where would be the best fixing points for stress plates and eye bolts for harnesses?
1990 mk2 1.6 daily
  • Opinions я Us
Re: harnesses
« Reply #9 on: 13 September 2010, 14:43 »
No.  You're going down at approx, or over 45 deg.  In a crash the harness will try and compress your spine.  Hideous, nasty, dumbf*ck idea used in WAAAAY too many cars as a shortcut.  You should have a harness bar in the cage that you need to install to get the 0-10 degrees angle which is best practice (see the MSA Blue Book for full details).
Mounting plates should be welded to the shell underneath, so the nut is on the underside.  See the Blue Book for detailed recommendations concerning this stuff.
Rummage at: http://www.msauk.org/ for further details instead of relying on other people's half-assed nolidge.
B*ggering about with your seat and belts is a stupid thing to do in a half-a$$ed manner.  Do not enter into it lightly.
